93 ZJ TCC Lockup Solenoid Failing Symptoms and Replacement
Discussion in 'Grand Cherokee' started by TinyInkognegroT, Nov 8, 2019.
  1. Nov 8, 2019 at 1:54 AM
    TinyInkognegroT
    Pretty sure I have a TCC Solenoid problem. I/We know my wires are burnt, disconnected, and damaged. What symptoms does a failing TCC Solenoid have and how can I test it ? That way I'll know if I need a whole new solenoid or just need to replace and rewire the wires/connector.
    If I need to replace the whole solenoid, how do I do that ?
  2. Nov 8, 2019 at 4:10 AM
    fix the wiring.
    then check continuity thru the solenoids at the transmission pass thru connector.
  3. Nov 8, 2019 at 5:56 AM
    TinyInkognegroT
    Roger that
  4. Nov 10, 2019 at 5:12 AM
    TinyInkognegroT
    I cut a 3 wire connector from a transfer case on a Jeep Grand Cherokee in the salvage yard... Can I just wire this to the wires already on the transmission and replace the old connector with this connector?PHOTO_20191110_070755.jpg 95 RH transmission connector (1).jpg
  5. Nov 10, 2019 at 7:55 AM
    is that the same connector on your trans - Will it plug in? :fingerscrossed:
    If yes just wire to match your solenoids.
  6. Nov 10, 2019 at 8:03 AM
    TinyInkognegroT
    No it wasn't...:( It was bigger than the one on my transmission. Can't seem to find too many 46RH transmissions at scrap yards around me. Does the 46RE have this plug too ? Noticed alot of 96-99 grand cherokee and cherokee with 4.0 straight 6 engines, do their transmissions have this plug ? Where else can I find a small 3 wire plug on a Jeep or Mopar vehicle ?
  7. Nov 10, 2019 at 8:38 AM
    TinyInkognegroT
    46re transmission plug is not the same as the 46rh. The 46rh has a 3-pin connector 46re has an 8 pin connector. Are there any Dodge trucks that have 46rh transmission?Screenshot_20191110-103641.jpg
  8. Nov 10, 2019 at 8:42 AM
    TinyInkognegroT
    Originally named A518, this A727 overdrive tranny was renamed the 46RH and began to be used in 1992 for the series 1500, 2500 and 3500 V8 engines as well as in the Ramcharger SUV 5.2L and 5.9L V8 -- Cut and pasted from http://www.smartpartsauto.com/dodge-ram-transmission.html
    These trans don't kook like they are interchangeable, the 95 fits- 93,94,95 and the 97 fits 96,97
  9. Nov 10, 2019 at 8:43 AM
    TinyInkognegroT
    So any Jeep or Dodge with a 5.2 or 5.9 liter engine years 93 through 95 should have the 46RH transmission.
  10. Nov 10, 2019 at 9:21 AM
    do you have in hand what is left of your connector?
    If you do go to a local auto part store and try to match, Maybe TPS, CMP, any 3 wire may be the same the 46 was used on many Mopar vehicles. It will match the OD and TCC solenoids which they likely have in stock to try.
    *why building LOCAL relationships matters
  11. Nov 10, 2019 at 9:32 AM
    maybe just maybe - cross referance mopar #5013933AA do not purchase without checking and cross referencing to a aftermarket part.
  12. Nov 21, 2019 at 6:41 AM
    TinyInkognegroT
    I rewired the solenoid connector wires and I still have the same problem. I cut the connector from the bad wire and reconnected new wire where the bad was cut off. Looks like to me, the solenoid itself could be faulty or the connector could be faulty but I can't find just a connector so I might as well replace the whole solenoid. How do I do that?
  13. Nov 21, 2019 at 7:23 AM
    Good job on the wire repair. Reconnect to see if the problem is resolved. From past experience with Honda transmission solenoids I unbolted the bolt(s) and simply replaced the problem part.
  14. Nov 21, 2019 at 8:18 AM
    TinyInkognegroT
    I did plug it back in and the problem still persist. What is why I think it's just either the whole solenoid itself is faulty or the plug is faulty.
  15. Nov 21, 2019 at 10:03 AM
    post #4 above has the wiring pin out -
    do you have 12v on center wire cavity #2?
    What is ohm reading 2 to 3 ?
    What is ohm reading 2 to 1 ?
