94 YJ hesitation no start
Discussion in 'Wrangler YJ (1986-1995)' started by YJ Noob, Dec 30, 2016.
  1. Dec 30, 2016 at 12:16 PM
    YJ Noob
    YJ Noob [OP] Member
    1994 Wrangler Sahara L6
    Hello Everyone,
    I have picked my first jeep and am bringing it back from the dead. I picked it up from an older woman who was taken for a financial ride by a shady part replacer....after the story she told me I refuse to call the guy a mechanic.
    1994 YJ, L6, automatic won't start. The motor turns all day but no bang. After inspecting the jeep I replaced the ignition coil, wires, cap, rotor looks brand new and plugs.
    Verified fuel with the valve on the rail and used starting fluid.
    I checked spark by plugging in a sparkplug to one of the cylinder wires and grounding it but no spark. I metered the voltage going into the ignition coil and got the 12V ground and 11.75 V strobe.
    After reading a few things I replaced the crankshaft position sensor. I am going to verify both fuse boxes for blown fuses. If anyone has any insight I would greatly appreciate it. If someone knows a jeep genius on Oahu I would also take that info as well
    Thanks
    Derek
  2. Dec 30, 2016 at 3:56 PM
    Subed for outcome
  3. Jan 2, 2017 at 11:54 PM
    YJ Noob
    YJ Noob [OP] Member
    Distributor was 180 out, discovered with a newly acquired "stuff a paper towel in the number 1 cylinder hole " trick. Still no sparks though. I used the key reset to get the OBD to give me codes and got 12, 22, 23, 24 and 55. I know 12 and 55 are normal. I am chasing a ground right now and will update when I get there
  4. Jan 3, 2017 at 8:42 PM
    C2T
    C2T Well-Known Member
    Richard
    Helena, Montana
    Jeep
    :fingerscrossed:
  5. Jul 24, 2017 at 12:47 AM
    YJ Noob
    YJ Noob [OP] Member
    Well everyone she is running now, ended up with the 12 battery , 22, 23, 24 codes . Then was given some help and told to check the grounds on the corespondent sensors. It turned out that all three related sensors we not grounded properly. I bit into the ground wire from the front coolant sensor and ran a fresh ground. She coughed then fired right up, took her for a stroll , now I just have to change the fluids out.
    aggrex, JKBob 25, OFFGRID and 2 others like this.
  6. Jul 24, 2017 at 6:23 AM
    Good to hear! Thanks for the update
  7. Jul 25, 2017 at 7:14 PM
    Cool. Must be one of the longest, I got her running threads I've read. 7 months. :jeep:
    So after keeping us on the edge of our seats for 7 months. You gotta share some pics dude. We like pics. :jeepwave:
