95 Grand Cherokee will not start
Discussion in 'Grand Cherokee' started by Valtyrr, Sep 5, 2019.
  1. Sep 5, 2019 at 10:54 AM
    Valtyrr
    Valtyrr [OP] Member
    95 Grand Cherokee Laredo
    Hey guys! This is my first Jeep, and I’m having some issues with it. A couple days ago it started having issues turning over, and yesterday officially gave up entirely. At first, I could pump the gas and coax it into turning over, but now turning the key does absolutely nothing.
    Battery is fine, alternator was kicking out 14 volts, just had the starter checked, replaced the fuel filter, put new plugs and wires in there (made certain they were all gapped appropriately and the firing order was correct), and there’s fuel in it.
    Before it stopped altogether, it made noises like it was really trying to turn over, but couldn’t. Since then, it doesn’t even try. We’re talking not even a click when the key is turned.
    Honestly, any ideas at this point would be incredibly helpful. Thanks!
  2. Sep 5, 2019 at 11:02 AM
    pumping fuel injection is pretty useless. But we do it anyway IDK.
    Which engine?
    How long has the CEL been on and what are the codes?
    So turning key and engine does not crank - am I correct?
    Shake snifter and if you can try to start in N.
    Can you use a wiring diagram and a test light?
  3. Sep 5, 2019 at 11:35 AM
    Valtyrr
    Valtyrr [OP] Member
    It’s the 4.0 straight six. No CEL, and I’m not sure on codes. I don’t have a reader at my house, and it’s not going anywhere right now, unless I tow it.
    Turning the key does absolutely nothing other than turn everything on inside the Jeep. No noise from the engine compartment whatsoever.
    Trying to start it in neutral didn’t yield any results either. Although after taking the starter off and putting it back on, it does make one loud clock when the key is turned.
  4. Sep 5, 2019 at 11:39 AM
    The below was previously posted for a 98 XJ.
    Take a multimeter and begin at the starter. Have someone turn the key to start and see if you are getting 12v to the starter solenoid. If not work your way back.
    Relay in the Power Distribution Center (PDC): Pull out the relay and use your multimeter to make sure there is 12 volts on the receptacle for pin 30, even when the vehicle is off there should still be 12 volts here. When the key is turned to start there should also be 12 volts on the receptacle for pin 86, if not I would look at your ignition switch. Also if you have continuity to ground on pin 85 your NSS is good.
    Neutral safety switch could be an issue: If you tested pin 85 as noted above you may be able to skip this step. Try to start in N, you can also by pass the NSS by jumping the B and C wires as noted on the NSS connector (maybe) under the hood on the passenger side by the oil dip stick. Still no start? move to something else.
    Ignition switch: Power into the switch should be on a Pink/Black wire and power out when in start position should be on a Yellow wire. Disconnect the switch and put your multimeter across those two contacts and turn the key, see if you have continuity. If not here is likely your problem.
    aggrex and spyder62 like this.
  5. Sep 5, 2019 at 3:37 PM
    Valtyrr
    Valtyrr [OP] Member
    Well, a buddy had a hunch, so we tried to turn the main crank, and it just barely moves. Looks like the motor seized up entirely.
  6. Sep 5, 2019 at 4:12 PM
    Did you remove the spark plugs when you tried to rotate the engine?
  7. Sep 5, 2019 at 4:54 PM
    Valtyrr
    Valtyrr [OP] Member
    I just did, and it definitely turns with the plugs out.
  8. Sep 5, 2019 at 7:42 PM
    All hope is not lost just yet. If you can turn motor by hand. EXTREMELY good chance it's not seized. Maybe some other major issue. But im sure its agreed. It's not seized.
  9. Sep 5, 2019 at 7:48 PM
    Valtyrr
    Valtyrr [OP] Member
    Best damn news I’ve heard all day. I’m gonna try swapping out the starter, and putting in better plugs. See if that helps out.
  10. Sep 5, 2019 at 8:06 PM
    @Valtyrr . Reaching here. Check ignition. Rotor, condenser. Cap. Yes, plugs. It's a single coil system. Honestly...not sure how to check it. But $25 to replace it. Plug wires....again...I'm reaching here. A compression issue. Vapor lock?
  11. Sep 16, 2019 at 1:03 AM
    Valtyrr
    Valtyrr [OP] Member
    Wound up being the starter, guys! Thanks for the help!
  12. Sep 17, 2019 at 10:44 AM
    95zj
    95zj New Member
    4.0 np231
    95 ZJ 4.0 np231 Laredo 3.5" on 33s
    3.5 IRO lift with all adjustable control arms and adjustable trac bars on 33" Discovery Maxx tires, ProComp 16x8 wheels, Redhead Durango Steering Gear Upgrade, 2.5 custom exhaust early dump by axle, dual core crown radiator
    @Valtyrr Hey man, looks like I got here too late.
    Same thing happened to me, took my started to get checked first thing and they said it was functioning just fine but in the end the fix was getting a new starter.
    Glad nothing is actually wrong with your jeep!
    Good luck bud and keep another ZJ on the road :homer:
