98 Grand Cherokee engine fit a 97 Wrangler?
Discussion in 'Wrangler TJ (1996-2006)' started by dballhead, Sep 27, 2017.
  1. Sep 27, 2017 at 12:52 PM
    dballhead
    dballhead [OP] New Member
    97wrangler
    None yet
    Can a 98 Grand Cherokee Laredo engine fit on a 97 Wrangler gearbox
  2. Sep 28, 2017 at 12:02 PM
    Depends on what motor. If it is the 4.0 it should be the same motor. I am not sure what you would have to do to get the 5.9 to fit, but I do have a friend that did do a 5.9 swap into a TJ. I should ad that if you have a 2.5 motor in the wrangler the 4.0 will not bolt up.
  3. Sep 28, 2017 at 6:23 PM
    dballhead
    97wrangler
    None yet
    Thanks offgrid yes I do have a 2.5 motor i might have to reconsider this swap
  4. Sep 28, 2017 at 6:23 PM
    dballhead
    97wrangler
    None yet
    Any suggestions anyone
  5. Sep 28, 2017 at 7:27 PM
  6. Sep 29, 2017 at 7:00 AM
    SmittyJeeper
    06 wrangler 4.0 6speed
    Not that this helps at all but I always wanted to do a 4.7 HO v8 swap in my tj. I think if you are going to spend the time and effort into it might as well go big and the 4.7 has parts everywhere so it can be done cheaply.
  7. Sep 29, 2017 at 7:04 AM
    IMO for the jeep cubic inches matter as HP+torque will be improved with little change in MPG. Go big
  8. Sep 29, 2017 at 9:14 AM
    If you do a 4.0 swap, try to find a 4.0 and tranny out of a jeep that someone is replacing with a bigger swap, or find a wrecked donor and pull the motor and tranny over for the swap. You will also need the ecm, motor mounts, belly pan (tranny mount), and likely the driveshafts. I usually recommend people to sell their current jeep and go find one with a 4.0. I believe that the 5.9 is a relatively easy swap into the 4.0 TJ. I have never done it, but again my buddy did it in a weekend and said it wasn't too bad.
