99 XJ Blower
Discussion in 'Cherokee' started by Waynepaw, Nov 25, 2019.
  1. Nov 25, 2019 at 3:47 PM
    Waynepaw
    Waynepaw [OP] Member
    Wayne
    99 Jeep xj blower works intermittently
    Hello, I have a 99 Cherokee XJ with 265+ on it. Still runs good. No rattles or shakes. My problem is the blower motor runs intermittently. I replaced blower resistor and control switches. I’m going to need some heat soon. Any ideas?
    Thanks!
  2. Nov 25, 2019 at 4:40 PM
    Check the connection to the blower motor, it could be loose or corroded.
    It could also be the vent selector switch not making good contact within itself.
    Waynepaw[OP] likes this.
  3. Nov 25, 2019 at 6:23 PM
    Blower motor could be getting hot and shutting down.
  4. Nov 26, 2019 at 1:40 AM
    Waynepaw
    Wayne
    I’ve replaced the control panel with 2 new ones. Getting same result.
    Prerunner1982 likes this.
  5. Nov 27, 2019 at 11:21 AM
    When it stops working, I would pull the connector to the motor and put a multimeter on it and see if you are getting any power and how much.
    If you are getting at least 12 volts I would look at replacing the blower motor.
    If no power or less than 12 volts work your way back, though it seems you have replaced everything else in the system as it is a simple system.
  6. Nov 28, 2019 at 6:47 AM
    Waynepaw
    Wayne
    I'm thinking I'll just replace the blower motor. Probably the better thing to do. Thanks!!!
