Ac compressor
Discussion in 'Cherokee' started by Indigoblazer, Jun 13, 2017.
  1. Jun 13, 2017 at 2:21 PM
    Indigoblazer
    Indigoblazer [OP] New Member
    1999 jeep cherokee
    Hi I have been scratching my head on a 1999 jeep cherokee with an AC problem. The compressor acts well, weird. I check the pressure on it and the high side goes to 300 and low is at 10 and the compressor kicks off until the low side get to 50 and comes on and happens again. No cold air comes out. Trying to figure it out. Any help would be great thanks.
  2. Jun 13, 2017 at 6:46 PM
    I had a 2000 XJ. It started acting very similar to that. Then the bearings went. Had to of coarse replace it. If it starts to makes a noise like there's a mess of marbles in it. Relatively cheap and easy to replace.
  3. Jun 14, 2017 at 4:57 AM
    Indigoblazer
    1999 jeep cherokee
    The compressor is working it like there is a clog in the system
  4. Jun 14, 2017 at 6:20 PM
    I'm not familiar with clogs in AC systems. Sorry.
  5. Jun 14, 2017 at 7:03 PM
    Check the orifice or pressure regulator.
  6. Jun 14, 2017 at 7:49 PM
    Jeeps have air conditioners? Wow, I really have to get me one of those.
  7. Jun 15, 2017 at 11:53 AM
    Indigoblazer
    1999 jeep cherokee
    Orifice tube was the problem covered in all kinds of stuff
  8. Jun 16, 2017 at 9:41 AM
    Good to hear!
