Aftermarket Stereo won't save settings
Discussion in 'Cherokee' started by TinyInkognegroT, Jun 24, 2019.
  1. Jun 24, 2019 at 9:24 PM
    TinyInkognegroT
    93 ZJ ... Settings won't save after car is turned off. Below are pics of my stereos wiring...Screenshot_20190624-231759.jpg Screenshot_20190624-231816.jpg Screenshot_20190624-231841.jpg
  2. Jun 25, 2019 at 5:00 AM
    Check the installation instructions. Constant 12V would solve your problem but could drain the battery if radio is left on. Perhaps the memory presets require additional wiring.
  3. Jun 25, 2019 at 8:19 AM
    TinyInkognegroT
    I would have to turn it off manually ? If so, that's fine but should the settings change if I turn it back on ?
  4. Jun 25, 2019 at 10:13 AM
    Assuming the radio is fine use a multimeter to confirm the wires have 12V power when key-on or key-off. Most of the time its simply wired incorrectly.
  5. Jun 25, 2019 at 12:35 PM
    TinyInkognegroT
    What wires would I need to connect to the constant 12v wire? Which is red/white or red/grey?
    An actual diagram for my year and model would be very helpful, I don't think the one I posted are right...
  6. Jun 25, 2019 at 2:46 PM
    TinyInkognegroT
    An actual diagram for my year and model would be very helpful, I don't think the one I posted is right
  7. Jun 25, 2019 at 3:22 PM
    TinyInkognegroT
    On the stereo harness (attached to the back of stereo), I have red, yellow, orange, and blue wires but im not sure of what they power. On my Scoshe wire harness for this year and model, I have the same color wires, but not sure of there functions either. Ill look up the diagrams for these so i can get better help...FB_IMG_1561500744461.jpg
  8. Jun 25, 2019 at 6:34 PM
    Are these pics the wiring diagram for your aftermarket stereo? Use a multimeter on the jeep wiring harness to determine which wire has the right 12V power. Matching colors may not be accurate with aftermarket radios.
  9. Jun 25, 2019 at 7:24 PM
    TinyInkognegroT
    No those are supposed to be the wiring for 93 Jeep Grand Cherokee...
  10. Jun 25, 2019 at 7:32 PM
    TinyInkognegroT
    Need to grab a multimeter.
