AMC 20 wide trac
Discussion in 'CJ' started by Eyy-sp12, Aug 24, 2020.
  1. Aug 24, 2020 at 12:58 AM
    Eyy-sp12
    Eyy-sp12 [OP] Active Member
    Charles
    1977 CJ5 with 304 and T-176
    T-176 Transmission with Dana 300
    Can the AMC wide trac 20 rear and 30 front axle be used on a 1977 CJ5?
  2. Aug 24, 2020 at 8:38 AM
    All CJ5s came with narrow trac axles. A tape measure can easily show the wider width. I would suggest either narrow trac or custom built axles, both easily available. The front 44 on my CJ is from a pickup truck that was narrowed from a specialized Jeep shop, and the rear 44 was actually oem. I really don't fancy the Model 20 rear as the tubes are very thin and prone to problems. The model 20 and 30 will easily have problems with tires over 33". I see you have the t-176 and the 304, both are excellent for the CJ5.
  3. Aug 31, 2020 at 4:14 AM
    Eyy-sp12
    Charles
    Jim Beam thanks for the reply . Thanks for complement . On the way I'm setting it up with t176 and 304 . Both off them are I've rebuilt and are ready . My Jeep however is not . I live in SC the head and humidity here . Pretty much put a hault on project . I work on it after work . Ut was getting to be to much . However when I start back . It will go pretty quickly . I need to find a shop . I found D44, rear and front on a 77 Cherokee chief . The front has locking hubs also . Wasn't a quadratact I think thats what there called . Man said both for 300$ if I help him get them off . I was like sure . Now I just need to find a shop . Would like to have like 3" on each side . The wheels I'm going to run or going to be 14.5 wide . Or maybe 13.5 . I'm leaning more toward the 14.5s . I'm planning on putting hydo assist on it also . Figure with those I will need it . Guess it would be best to find a 4x4 shop to do a cut down . If I do this can I custom order axle shafts ? How would I get that right ? Thanks for the advise .
  4. Aug 31, 2020 at 4:25 AM
    Eyy-sp12
    Charles
    Oh yeah one other thing . You may have seen where I have posted questions about soa conversion. In your opinion . If you have any knowledge of soa , like the way it rides . What would you recommend? I know you're a knowledgeable person with Jeeps. Me not so much . I believe using the yj springs and a good shock like fox . Would give it a nice ride on the road . I'm making my jeep y own . A restomod if you will . I would like any experience you have of this . Thank you
  5. Aug 31, 2020 at 10:51 AM
    Those are really wide wheels! I do think they are a bit much for a 304. If you plan on getting axles cut, I would suggest a reputable shop do the whole operation. Get some real low axle gears. For the transfer case the D300 will accept a 4 to 1 gearset. For a brake booster you might be able to get by with a dual diaphragm type booster. A custom spring maker can make you a set of springs designed just for a spring over also. Shocks from my experience are usually "You get what you pay for for" and a leaf spring CJ requires a good set. Getting the right air pressure in the tires is also pretty critical on and off road and either a small dive tank or a engine driven air compressor will work. Building a CJ the way you want and affording to do it are two different things.
    LYFZGOOD likes this.
  6. Sep 1, 2020 at 6:48 AM
    Eyy-sp12
    Charles
  7. Sep 1, 2020 at 7:03 AM
    Eyy-sp12
    Charles
    I really want to do it this way . May get in touch with deaver. I have 5k set back for project . I know the 304 is not a Ls . I do want to keep a AMC engine in it . I have thought nothing about t case gearing but I was planning on getting the rearend geared in . In other words make power with them . So to speak . Later on I'm planning on putting a roller cam , eldlebrock performer , and a fi tech or holly efi throttle body on it . To increase power but mostly torque out put . When you get time if you dont mind elaborate on t case . I don't understand that part . I thought with 35s the D300 would be fine . Would it put a lot of strain on it ? As always thanks for your help with advise . I'm not a rich man so i want to get it right . Don't want to have weak link . Thanks again
  8. Sep 1, 2020 at 12:26 PM
    If the engine has a lot of miles You may want to rethink the cam and the performance work if you’re not planning on rebuilding I have seen them blow the bottom end out when you would do something like that to an engine. My brother back in the day had a 1976 Chevy Silverado 350 put a different cam in it with quite a few miles on the motor made it start using oil. Has anybody else experienced that to confirm
  9. Sep 1, 2020 at 2:00 PM
    Transfer case regearing is for going slow over a rock bed or a really steep hill, with the increased torque to the rear wheels you would have to go easy on the skinny pedal. When choosing rear gears with a 35" tire and no overdrive, calculate in traveling at highway speeds, like a 3:5 to 3:7. A front and rear traction aid is always good in the loose dirt. I would suggest a small tire as you can get away with.
  10. Sep 1, 2020 at 2:48 PM
    Eyy-sp12
    Charles
  11. Sep 1, 2020 at 2:57 PM
    Eyy-sp12
    Charles
    It's prett
    Thanks for the advise I believe I may do that . Hell it's gonna be spring anyway before I have it ready to drive . This SC heat and humidity will drop you this time of yr.
  12. Sep 1, 2020 at 3:03 PM
    Eyy-sp12
    Charles
    The 304 probably don't have but 4k on it . Still I may hold out on that also . Although I might put efi on it . Just to make it more efficient .
