Another 2011 air suspension issue
Discussion in 'Grand Cherokee' started by Overhemiland, Mar 4, 2020.
  1. Mar 4, 2020 at 3:58 AM
    Overhemiland
    Overhemiland [OP] Member
    Hello,
    The 2011 has been Giving the “service air suspension immediately” warning off and on lately, when it’s not having a bad day everything works as it should, it raises And drops, sounds normal etc... this morning on my wife’s way to work it said “reduce speed for suspension setting” she was in auto mode like always and going 50mph...
    What could be causing this?
  2. Mar 5, 2020 at 4:01 AM
    Overhemiland
    Update, when started this morning it says it was in park mode setting, we definitely didn’t put it in park mode when we shut it off last night, would it do this automatically and I just haven’t noticed it before? I’ve only owned this jeep for two weeks so that’s possible I suppose, if not and I had a leak wouldn’t all four sides have to be leaking for it to go all the way to park mode level? I’m stumped. Yesterday it told my wife to reduce speed for the mode she selected, which she didn’t select anything, she keeps it in auto and never messes with ANY of the settings at all... just starts it up and drives.
  3. Mar 5, 2020 at 11:35 AM
    Overhemiland
    And another update... wife just called and said “looking at her Jeep it looked was low in the front sitting in the parking lot.” And again she hasn’t presses any buttons or turned the dial...
  4. Mar 6, 2020 at 4:17 AM
    Overhemiland
    Early this morning I went out and started the Jeep, it said normal ride height or something to that degree... but it is not normal, lol, the front is still low. Found the fuse was blown for the air ride, makes sense because I haven’t heard the compressor working in the last couple days and the front has been down, maybe a leak in the front overworked the compressor and blew the fuse?
  5. Mar 12, 2020 at 9:27 PM
    Jrgabriel
    Jrgabriel Well-Known Member
    Do you believe your issue may be related to the TIPM and bypass on the fuel pump relay?
  6. Mar 13, 2020 at 6:59 AM
    Overhemiland
    Just had it towed to the mechanic last nite... he just called and said the air compressor has a crack in the rear☹️, after that I’m guessing air line leaks as well , but who knows... what a bummer!
  7. Mar 25, 2020 at 9:55 AM
    Overhemiland
    The compressor had a crack in it, replaced with another one, and the new one doesn’t seem to build enough pressure, the mechanic said he could hold is thumb over the hose and it didn’t have enough pressure to blow his thumb off. Would a broken compressor cause the Jeep to go all the way down front and rear?
  8. Mar 25, 2020 at 10:32 AM
    That should explain the "service the air suspension" issue as the compressor can't pump to the specified pressure requirements of the air suspension. Hopefully another pump will fix it as well as any leaky connections or lines
  9. Mar 27, 2020 at 5:38 AM
    Overhemiland
    So it’s at the dealer now, They charged the system up with nitrogen and they can’t find any leaks but the compressor still won’t shut off it just keeps running, so they want another hour to diagnose that problem so I gave them the go ahead.Maybe a relay? Hopefully something simple because this is getting expensive
  10. Mar 27, 2020 at 10:23 AM
    Overhemiland
    Just talk to the service department at the dealer, the jeep is now all the way up but they can’t get it to deflate, he took the technician off the job for a little bit because he was getting real frustrated and wanted to give him a moment to calm down. He said something like “he tells the computer to do one thing and it won’t or it does the opposite”? Getting pretty nervous.
