Biggest tires on a stock TJ?
Discussion in 'Wrangler TJ (1996-2006)' started by CJ3, Sep 3, 2016.
  1. Sep 3, 2016 at 10:24 PM
    CJ3
    CJ3 [OP] New Member
    1997 jeep tj
    So I recently bought a 1997 tj for my first car!! The only complaint I have is that the stock wheels and tires are tiny, and a lift kit will break the bank. So does anyone know the biggest tire I could squeeze in there?? I am hoping for a more rigid look! I attached a picture of my jeep below. Thank you for your help!
    -Chris
  2. Sep 3, 2016 at 10:47 PM
    31" tires
  3. Sep 4, 2016 at 7:31 AM
    C2T
    C2T Well-Known Member
    Richard
    Helena, Montana
    Jeep
    I agree with Bob...31". You will likely get a little rubbing at full turn but nothing bad if you keep at 10.5" width or less.
    Unsolicited advice alert!
    You can put a leveling kit such a quadratec's and go up to 32" tires. It will help with the "look" you are going for as well. It is a $120 kit and can be installed pretty simply in your driveway. it uses all your stock hardware so the only change is a small increase in height.
  4. May 8, 2018 at 5:06 PM
    Jim53
    Jim53 New Member
    Jim
    06 TJ
    Tires 9000pd winch
    I'm running a 255 70 R16 with no problems whatsoever on a stock 2006 Wrangler X TJ
  5. May 8, 2018 at 5:28 PM
    Welcome! Good to share what fits. Post some pics in your intro thread
  6. May 8, 2018 at 6:22 PM
    Welcome to the forum @CJ3.
  7. May 8, 2018 at 6:35 PM
  8. May 8, 2018 at 6:40 PM
    Crap....did I miss some one. Lmfao. Thanks @aggrex. Phew...that was close. :eek:
  9. May 9, 2018 at 7:27 AM
    Rc Jeep
    Rc Jeep Well-Known Member
    Ryan
    '16 Rubicon
    If you take off the end caps on your front bumper you can fit 32s.
    Edit: with rubbing
  10. Oct 20, 2018 at 5:48 PM
    gowenby2002
    gowenby2002 Member
    Gordon
    Jacksonville, FL
    2002 white TJ 4.0 auto
    stock late model wheels/street tires with adapters, 7 in. stock type fender flares, 4 core rad/elec.fan, all LED lights, spray-in bed liner in cab, front home-made tow brackets for flat-tow
    I have 285/75-16 on 8in. wide Blackjack GEAR wheels----no problem stock 2002 tj
  11. Oct 20, 2018 at 7:08 PM
  12. Oct 21, 2018 at 6:09 AM
    This is the equivalent to 33x10.50x16r
  13. Oct 21, 2018 at 2:20 PM
    Welcome!!
  14. Oct 21, 2018 at 7:19 PM
    Jeep4Life
    Jeep4Life Well-Known Member
    2012 Jeep Wrangler Unlimited
    Welcome from Florida CJ3!
    I thought my jku was stock and have 255 75r17 tires on it which are 32". How would I find out if mine has a lift or not?
  15. Oct 22, 2018 at 8:34 AM
    32s will fit a stock jku. You can take it to a4x4 shop and ask their opinion. I bet they'll tell you without charging you. They'll want your future business.
  16. Oct 22, 2018 at 9:26 AM
    Park next to a stock JKU and admire the view LOL
