Brand of Fuel Pump
Discussion in 'Wrangler YJ (1986-1995)' started by MacQ, May 20, 2020.
  1. May 20, 2020 at 8:22 PM
    MacQ
    MacQ [OP] New Member
    Mike
    Red 1991 YJ
    So after all our diagnostics on our 91 YJ with a 2.5, we're 99% sure it's a bad fuel pump (thanks to all who chimed in on previous postings). So in looking at a replacement, what brand to you all go with? Do you do a Mopar at $$$$ dollars or something else at $$ to $$$ dollars? Believe me, I won't go with one valued at $ dollars (the el cheapo).
    In the past, I have gone with Delphi and Denso for my Chevy trucks and Toyotas. Have never had a problem with them. What say you?
    Thanks!
  2. May 20, 2020 at 8:51 PM
  3. May 21, 2020 at 1:43 PM
    Discount code for rock auto 138155120127884664
  4. May 21, 2020 at 4:35 PM
    Replacing an in tank fuel pump is quite a job. I have heard of guys making a door over the fuel pump location in the bed of the Jeep for a quick change if you think it might happen again in your lifetime. On my CJ with fuel injection, I have an external electric pump that has been in there since '07. I once thought it went bad and swapped it out with a spare on the interstate. Turned out to be a bad ignition control module.
  5. May 21, 2020 at 5:01 PM
    It’s really not that bad. I would never cut a hole. Take ur time and do it right.
    A job worth doing it a job worth doing right the first time.
