Can I use a hard top without hooking up the rear wiper?
Discussion in 'Wrangler JK (2007-2017)' started by Billy1234, Apr 3, 2017.
  1. Apr 3, 2017 at 5:47 AM
    Billy1234
    William
    1997 XJ 2 door
    None yet
    I have a soft top n found a nice hard top for sale near me but it has the wiper and all. I dint havr the hook up for rear wiper can i still use this hardtop?
  2. Apr 3, 2017 at 8:17 AM
    I don't see why not.
  3. Apr 3, 2017 at 6:08 PM
    If your handy get some wire, switch, 12V and it could become operational
  4. Apr 4, 2017 at 4:22 AM
    Billy1234
    William
    1997 XJ 2 door
    None yet
    That is actually a pretty good idea i didnt think of that thamk you
  5. Apr 4, 2017 at 6:04 AM
    The Brit
    The Brit Member
    Karl
    I don't know if you've checked already but check around the roll cage in the back under the padding and a lot of times manufacturers will just include the wire harness for all the different hook ups so your pigtail might already be there to hook into just a thought. But otherwise you should definitely able to run a hot tub without the wiper been hooked up Good luck on your project
  6. Apr 4, 2017 at 8:15 PM
    C2T
    C2T Well-Known Member
    Richard
    Helena, Montana
    Jeep
    Karl is correct, the wires should be there as should the wiper fluid hose.
    The Brit[QUOTED] likes this.
