Carburetor issues cj5
Discussion in 'CJ' started by Coop1979, Aug 16, 2019.
  1. Aug 16, 2019 at 6:53 AM
    Coop1979
    Coop1979 [OP] New Member
    Craig
    1979cj5
    Have 79 cj5. With 258. Having carb issues. Have Weber carb will not run on this jeep. Need 2100 series carb with 1.08 Venturi size. 2bbl. So I'm told. Any info on this is appreciated. What do I need and where can I get it does anyone have a part number for local part store for a carb that works
  2. Aug 16, 2019 at 4:22 PM
    You should be able to look up all this info. The Weber swap is pretty common, I would suggest YouTube for more info. From what I understand a fuel pressure regulator is needed also.
  3. Aug 16, 2019 at 8:44 PM
    The internet is pretty amazing. You just have to do the research. :facepalm:.
