Only stays running if I keep my foot on the gas
Discussion in 'CJ' started by KhanginC, Apr 22, 2024.
  1. Apr 22, 2024 at 7:56 PM
    KhanginC
    KhanginC [OP] New Member
    Jo
    85 CJ7
    Hi I have an 85 CJ7 that is not firing on all cylinders. I replaced the distributor cap and the rotor and it fired up but only stayed running if I kept my foot on the gas. I am consented I do t have my wires hooked to the distributor cap correctly and have tried finding a diagram. Past that after replacing those parts where do I go next.
    Separate issue on my carburetor I have several hoses that are not hooked up the previous owner just put bolts in the end of them and I can’t find the appropriate schematics to see where the heck they go.
    I am a new Jeep owner and I will humbly say a beginner mechanic. Any guidance or information is much appreciated.
  2. Apr 23, 2024 at 5:19 AM
    rick1956
    rick1956 has dirty fingernails
    Rick
    Edgewood, Washington
    81 CJ-7
    Lots of mods, but they were already in place. MY mods are REPAIRS!
    Do you have access to a compression tester? You might have an internal issue. Here's to hoping not...
  3. Apr 23, 2024 at 10:58 AM
    KhanginC
    Jo
    85 CJ7
    No but I can get ahold of one
  4. Apr 27, 2024 at 8:07 PM
    Since another member suggested you do a compression test. And you need to pull the plugs.
    I'd suggest you look closely at the plugs. They can be a very good indicator of certain issues. Ignition, Air/fuel etc. You mentioned replacing cap etc.Whens the last time you replaced the wires....coil? Tubes from the carb are most likely vacuum tubes for emissions. Then again in '85. What emissions. Lol. And if you do a compression test. Don't put any plugs back in to test.
    Unfortunately, I have no idea of your experience level other than being a beginner. And of coarse I don't mean to point out the obvious. But I take it you have a misfire. There's several issues that would cause that. Overheating, ignition, A&R...
    It's hard to diagnose issues without actually being there. Nah mean....
  5. May 1, 2024 at 8:21 AM
    MTgeezer
    MTgeezer Well-Known Member
    John
    55 CJ 3B
    This may just be a vacuum leak, especially with a bunch of disconnected/"plugged" hoses. I would start checking it by spraying (CAREFULLY) carb cleaner or starting fluid on any suspect areas. If the engine speeds up, you have found the leak. This is absolutely best done outside and personally, I would have a fire extinguisher at the ready.
