Compression numbers
Discussion in 'Wrangler YJ (1986-1995)' started by Jeepjoc, Nov 30, 2017.
  1. Nov 30, 2017 at 2:50 PM
    Jeepjoc
    Jeepjoc [OP] Well-Known Member
    Dennis
    Albertville, AL
    1995 YJ Wrangler Rio Grande
    What is considered good cylinder compression numbers for a 2.5L engine and what difference range is considered acceptable?
    Thanks - MGjoc
  2. Nov 30, 2017 at 4:53 PM
    From what I can gather, 120 to 130 psi +/- 20% across all cylinders.
  3. Nov 30, 2017 at 5:35 PM
    Offroad798
    Offroad798 Well-Known Member
    Florida
    2015 Rubicon
    Here is my 2 cents worth. From what I remember when I work as an auto tech they said at least 100 psi for each cylinder with no more then 10 % variation between the highest and lowest. Chrysler says 120 - 150 psi with max variation of 30 psi between cylinders. For 2.5L engine. Hope this helps. FYI - to run a compression test - engine warm near operating temp, disable fuel system ( relay or fuse), remove all spark plugs, hold pedal on floor (throttle body wide open) - crank all cylinders the same number of times usually 5 -6 good luck
