Connecting rod end play
Discussion in 'Performance & Tuning' started by 87joop, Oct 8, 2017.
  1. Oct 8, 2017 at 11:19 AM
    87joop
    87joop [OP] New Member
    Raymond
    87 wrangler yj
    2.5" suspension lift, 3" body lift, 4.10 gears, ax15 tranny swap, 258 bored .030 over and deck .015 in the hole, offset ground crank, custom H beam connecting rods and pistons, four barrel edelbrock carb, four barrel intake, high flow oil pump, moderate cam, cat back exhaust, 3 core aluminum radiator, t case lowering kit, distributor upgrade, ported and polished stock heads
    What should the connecting rod side to side end play (axial) be at most on a 258 straight six
  2. Oct 8, 2017 at 11:34 AM
    Welcome to the site!
    I found this in the 1988 FSM:
    010-.019 rods side play
    OFFGRID likes this.
