Dana 30 front axle questions
Discussion in 'Wrangler YJ (1986-1995)' started by 95YJ, Sep 28, 2017.
  1. Sep 28, 2017 at 5:39 AM
    95YJ
    95YJ [OP] Member
    Conner
    1995 Jeep Wrangler YJ
    So I have a dana 30 front axle that I'm installing lockers on. How do you tell if it is a c-clip or non-c-clip axle?
  2. Sep 28, 2017 at 7:07 AM
    SmittyJeeper
    06 wrangler 4.0 6speed
    Front axles don’t fall under the “c” clip Category. You will either have a high pinion axle or a short pinion axle either way they disassemble the same. Take a pic I can tell you which it is. High pinion will have Reverse cut gears and short pinion will have standard cut gears.
    95YJ [OP] likes this.
  3. Sep 28, 2017 at 7:16 AM
    Should be a high pinion and if it is like my XJ axles there are no C-clips as the hubs hold the axle shaft in the axle.
    95YJ [OP] and OFFGRID like this.
