"deer", brush guard advice
Discussion in 'Cherokee' started by 2oldjeeps, Mar 19, 2018.
  1. Mar 19, 2018 at 9:30 PM
    2oldjeeps
    2oldjeeps [OP] Well-Known Member
    98 and 2000 xj's 99wj
    looking at guard on ebay by seller speed_daddy for $260.
    i dont know how they mount?
    quality comments?
  2. Mar 20, 2018 at 4:38 AM
    JeepMafiaMama
    JeepMafiaMama Well-Known Member
    Lisa
    Central ny
    You should be able to email the guy...maybe he can send you better pics n more info.
  3. Mar 20, 2018 at 5:30 AM
    It appears to use holes in the front frame area including the ones that your front sway bar uses. Same holes factory tow hooks or a front mounted receiver hitch would use.
  4. Mar 20, 2018 at 10:15 AM
    Link doesn't open for me to the specific guard you're referring to but as JMM mentioned the seller should be able to send installation pdf files. From there you can determine whether the guard is decorative or offers some low speed protection. Frame attachment points usually equate to better low speed protection.
  5. Mar 20, 2018 at 10:15 AM
    2oldjeeps
    tnx, ill look under today.
  6. Mar 20, 2018 at 10:46 AM
  7. Mar 20, 2018 at 11:08 AM
    Try this coupon to see if it works for your vender on ebay. Won't know without trying.if not it could work for other stuff
