Delete catalytic converter? or not.
Discussion in 'Wrangler TJ (1996-2006)' started by gowenby2002, May 24, 2021.
  1. May 24, 2021 at 6:27 AM
    gowenby2002
    gowenby2002 [OP] Member
    Gordon
    Jacksonville, FL
    2002 white TJ 4.0 auto
    stock late model wheels/street tires with adapters, 7 in. stock type fender flares, 4 core rad/elec.fan, all LED lights, spray-in bed liner in cab, front home-made tow brackets for flat-tow
    Have 2002 total stock 4.0 auto Wrangler 183,000 miles. Good idea to delete catalytic converter or not? do not see any O2 sensors anywhere in exhaust system.
  2. May 24, 2021 at 9:45 AM
    Due to the age and @183k the exhaust system may break apart during disassembly. If the CAT is deleted there may be an issue passing inspection with the local DMV or a persistent CEL. But a fresh CAT could be like a fresh set of lungs.
  3. May 24, 2021 at 3:41 PM
    gowenby2002
    Gordon
    Jacksonville, FL
    Thanks for response, after double checking while installing a trans cooler, it does have o2 sensors. one downstream from each manifold cat., then two exhaust pipes join together that goes back 3 ft. to a larger cat., then to factory muffler. What I was thinking of is to do away with the cat. at the muffler as there is NO o2 sensors after the two at the exhaust manifold. Just wondering has any body else done this with no problems as I don't want to cause a lot of problems that I now do not have, thought it might help it breathe a little better. Thanks again for your thoughts and experiences and comments...
  4. May 24, 2021 at 3:43 PM
    gowenby2002
    Gordon
    Jacksonville, FL
    Also do not have any DMV inspections to deal with( this is FL, still have just one or two freedoms left)
  5. May 24, 2021 at 5:59 PM
    On a different vehicle I was unable to salvage any of the old 16 yr old exhaust pipes, muffler or CAT. The bolts+nuts morphed into rusty slag and had to be cut off. Ordered an aftermarket exhaust system from Rock Auto and it bolted together without any welding. If you don’t have any sensors post CAT then maybe your mod will work. 12454B6A-17B0-4D91-B75D-B6FAFFB16B05.jpg
  6. Jun 5, 2021 at 11:18 AM
    Justanotherjeeper
    Ontario, Canada
    2024 4xe Rubicon
    Good enough as it is
    @gowenby2002 - removing your CAT will lessen the back pressure and strain on your engine, and probably increase its longevity. Its totally doable, let your conscience be your guide. However, it will be louder. To speak for the environment, which can't speak for itself, I would only say that its there for a reason, to keep the air we all breath a little cleaner. That's a good thing, and worthy of spending a few dollars on, irrespective of laws, inspections and regulations. It feels good doing the right thing and being part of the solution no matter how small an act that may entail. Whenever I'm behind someone driving an old beater vintage car, or a muscle car restored on the cheap, I hate breathing their fumes. Don't be that guy, please.
