Door weather stripping
Discussion in 'Wrangler YJ (1986-1995)' started by Peeler, Sep 29, 2017.
  1. Sep 29, 2017 at 8:55 AM
    Peeler
    Peeler [OP] New Member
    Danny
    1991 wrangler
    None
    Hello everyone.
    Looking to buy weather stripping for the full steel doors on my 1991 wrangler.
    The trouble is my weather stripping is glue on. All the stuff I order is held on with pins.
    No holes are drilled in the door for the pins. VIN says it was made in Canada. Winter is
    coming on and would like to replace it. Anyone else run into this problem and what was your solution?
    Thanks in advance.
    Danny
  2. Sep 29, 2017 at 7:12 PM
    Welcome! If you can't get the right weather stripping can you cut off the pins and use some 3M double-sided tape?
  3. Sep 29, 2017 at 10:55 PM
    Welcome!
  4. Sep 30, 2017 at 6:25 PM
    Welcome to the forum Peeler.
  5. Aug 20, 2018 at 12:44 PM
    Mxdad777
    Mxdad777 Member
    1987 Wrangler YJ
    Are you sure you don't have any holes? Mine was also glued on and was a real pain to get off. Once I got it off, the holes were there under the rubber and glue. I used a razor blade to cut most of mine off and then a wire wheel to take off the remaining rubber and glue. Since I was painting my doors, I didn't have to worry about ruining the paint. Based on my experience you won't be able to get the old off without ruining the paint. Don't sweat it too much, just be careful and touch it up when you're done. The new weather strip will cover most of it up anyway. Any good automotive paint store can mix up some paint to match your Jeep and put in a rattle can for you.
  6. Aug 20, 2018 at 12:46 PM
    Mxdad777
    Mxdad777 Member
    1987 Wrangler YJ
    Oops, I didn't realize this thread was a year old when I posted.
    DustStorm4x4, JKBob 25 and chris4x4 like this.
  7. Aug 20, 2018 at 2:53 PM
    No worries. Never know if the OP will post if the issue was fixed or not.
  8. Jan 6, 2019 at 4:33 PM
    Peeler
    Danny
    1991 wrangler
    None
    Sorry about the reply time.
    Yes the are held on with pins. Pins were broke and other owner just glued them back in place.
    Thanks for the help
    Danny
  9. Jan 6, 2019 at 7:51 PM
    Welcome from DFW
