Electric lockers for stock dana 44 rear axle with 3.21 gear ratio?
Discussion in 'Wrangler JK (2007-2017)' started by jeepavalanche, Jul 24, 2020.
  1. Jul 24, 2020 at 3:22 PM
    jeepavalanche
    Are there any available selectable electric lockers for stock dana 44 rear axle with the 3.21 gear ratio on the market?
  2. Jul 24, 2020 at 4:51 PM
    Yup and make sure to change those axle ratios at the same time.
    jeepavalanche[OP] and LYFZGOOD like this.
  3. Jul 25, 2020 at 7:14 AM
    jeepavalanche
    The reason I asked if they make them for the 3.21 is because I like my gears there. There's plenty of torque and I get the best gas mileage. That 3.6 is a great motor.
  4. Jul 25, 2020 at 12:12 PM
    I’m glad you are happy with those 3.21 axle ratios as most of the Jeep forums do not like them. If you go for larger tires or heavier armor in the future the effect of those axle ratios will be magnified. It’s going to increase costs somewhat but whenever lockers are installed is the absolute best time to consider axle ratios that match future plans and vice-versa.
  5. Jul 25, 2020 at 12:20 PM
  6. Jul 25, 2020 at 3:59 PM
    jeepavalanche
    I have 35s on the jeep. Its not a vette but it has much more torque than my previous one did with the 3.8litre. Im happy with the 3.21ratio in the rear. Just hoping to find a locker for that ratio on a dana 44. So far no luck. :( forgot to mention it has front, rear smitty bumper with winch and a swing out tire carrier.
