Engaging 4WD
Discussion in 'Cherokee' started by Jm157, Jan 18, 2020.
  1. Jan 18, 2020 at 9:12 AM
    Jm157
    Jm157 [OP] Member
    1995 Jeep Cherokee SE
    Is there a certain process to follow when putting my 1995 Cherokee into 4WD, I haven’t done it yet but getting that it’s winter it would be helpful in getting out of my driveway and I don’t want to ruin anything on the car in trying to do it.
  2. Jan 18, 2020 at 9:52 AM
    Put in Neutral, while slowly rolling, and shift it directly, and firmly, into Low Range.
  3. Jan 18, 2020 at 9:54 AM
    Generally the transfer case is shift-on-the-fly. In other words moving the lever from 2WD to 4H can be done in motion up to 50ish mph (refer to manual). Now 4L is recommended to be engaged at 1-2 mph or stopped. Now if you have full-time it will be similar for 4L.
  4. Jan 18, 2020 at 9:55 AM
    @aggrex is correct. My post was simply when shifting into low :)
  5. Jan 18, 2020 at 10:02 AM
    Good plan as you don't want to find out things are not working in the middle of a storm. Engaging 4H and/or 4L will give you a greater appreciation of your jeeps capability. Perhaps try the system out on a dirt road so there is less binding of the system. Since you're asking about jeep 4WD systems I strongly recommend these part-time systems be left in 2WD while on dry pavement.
  6. Jan 18, 2020 at 11:54 AM
    Jm157
    Jm157 [OP] Member
    Thank you all so much for helpin out
