Engine oil
Discussion in 'Cherokee' started by Jm157, Feb 19, 2020.
  1. Feb 19, 2020 at 5:36 AM
    Jm157
    Jm157 [OP] Member
    1995 Jeep Cherokee SE
    Hi guys, I hope you all are having a good morning, just out of curiosity my Jeep cherokee repair manual (XJ) said I can run 5w-30 if it gets especially cold out, however it says I can also run 10w-30 but that it shouldn’t be run below 0 degrees F, but under my hood they wrote on it saying they used 10w-30, next time I change my oil should I put in 5w-30 because it’s winter time or put 10w-30 and just use the same stuff they did?
  2. Feb 19, 2020 at 7:38 AM
    I would run 5W30 for easier starts and less cold start wear as stated in the manual.
    JKBob 25 and CZJ7 like this.
  3. Feb 19, 2020 at 1:48 PM
    Another way of looking at it would be to run a heavier weight oil as a '95 xj probably has a lot of miles on it. Either way changing it at the proper intervals is critical. Dirt and metal chips don't lubricate very well.
    aggrex[QUOTED] likes this.
  4. Mar 2, 2020 at 7:12 PM
    cpttuna
    cpttuna Well-Known Member
    earl
    XJ-98-00-01-and 01
    ss exhaust-viper coil
    Is your vehicle in Maine or Florida? garage kept or left out? I have run 30 weight in the jeep I leave in the heated garage. Had no problems in the winter.
