Engine swap from a VW Passat?
Discussion in 'CJ' started by Jeep Newby, May 30, 2017.
  1. May 30, 2017 at 7:31 PM
    Jeep Newby
    Jeep Newby [OP] Member
    79 cj7
    Any thoughts on 1.8t swap from a VW Passat?
  2. May 30, 2017 at 9:09 PM
    Better off to go with a Mecedes 300sd engine. Already has companies making adapters and engine mounts for the swap, but in answer to your question I think it would be a hard swap. Can you source the parts to make the swap?
  3. May 31, 2017 at 3:34 PM
    Unless its free it seems to be more work than what 184 LB-FT torque can do for you.
