Faded Driver Side Headlight
Discussion in 'Electrical' started by bdaly163, May 30, 2019.
  1. May 30, 2019 at 5:23 AM
    bdaly163
    bdaly163 [OP] New Member
    2004 Jeep Wrangler
    Hi everyone!
    I have a 2004 Wrangler. Recently, my driver side headlight is not as bright as the other one. I replaced the bulb, and it's still faded. Any advice on what it might be and how to fix it? Thank you!
  2. May 30, 2019 at 5:44 AM
    Welcome from Oklahoma.
    If there is a ground wire for that headlight you might check and clean the ground real good.
    Jeep4Life, Harleymick and JKBob 25 like this.
  3. May 30, 2019 at 10:01 AM
    Welcome @bdaly163 as mentioned for the ground connection confirm proper voltage to the bulb and look for damaged wires/ loose connections. Perhaps test with another head lamp.
  4. May 30, 2019 at 6:51 PM
    And if that don't work the jeep is done feel free to drop it off at my house lol
  5. May 31, 2019 at 7:31 PM
    2" Superlift kit. 315/ 70/17.
    :rofl:....Hey...TJ came up with a good one. :rofl:. Oh....I'm sorry. Ummm. Yeah...I suck at electrical issues. But I am learning. Start with the basics. Grounds and bulbs. And hope it's not a bigger issue.
    BTW. Welcome to the forum. :jeepwave:
    TJ_abuser likes this.
  6. May 31, 2019 at 7:50 PM
    Chasing electrical shorts in any car sucks I was trained by the army in avionics and it still gets me chasing my tail 1/2 the time starting with the basics first is always best like Awrench says kiss keep it simple stupid
  7. May 31, 2019 at 8:15 PM
    Harleymick
    Harleymick Well-Known Member
    Mick
    1999 Jeep Wrangler Sahara
    I looked up the word 'cool' in an online dictionary. All it said was Awrench!
  8. May 31, 2019 at 8:30 PM
    I was trained by the Army to fix generators, really just learned how to use a multimeter and read a wiring diagram. :rolleyes:
  9. Jun 1, 2019 at 12:13 PM
    Same here man well I learned transistors caps etc.
  10. Jun 1, 2019 at 12:14 PM
    I know thats right Awrench is so cool sometimes he has to stop to let cool catch up with him!
  11. Aug 15, 2019 at 6:20 AM
    911 SUPERVISOR
    911 SUPERVISOR Member
    Danny
    1999 grand cherokee laredo
    If it is a cloudy lens I make a mixture of lemon juice from a fresh squeezed lemon and some baking soda and make a paste. Rub it on the lens with a clean cloth, let it dry then rinse it off, next use some high grade car wax and apply to the lens let dry then wipe off. Works great on outside film and actually will get some of the inside film also
  12. Aug 15, 2019 at 5:15 PM
    A simple way to check for a weak ground would be to run a jumper wire from the battery negative to a location close to the light or directly to the black wire coming from it.
