Failure Rate of TPM
Discussion in 'Wrangler JK (2007-2017)' started by WOFIII, Nov 19, 2019.
  1. Nov 19, 2019 at 10:37 AM
    WOFIII
    WOFIII [OP] New Member
    2013 4-Door Wrangler Unlimited
    Question for the group. I just had 4 new tires installed by the dealership for JK 4 dr. A few weeks later, my Tire Pressure Warning light came on but with no indication as to which tires (we had a cold snap which I know impacts tire pressure). The Service Dept is now telling me all 4 TPMs have failed at the same time. Is this even possible? Could this go back to installer error when tires were installed (during warmer weather)? Seems to me that such a simultaneous fail rate would be highly improbable. Appreciate any ideas.
  2. Nov 19, 2019 at 4:41 PM
    Welcome to the forum @WOFIII .
    Highly unlikely all 4 went at once. The time of year, weather, shouldn't have any effect on their failure. If in fact they failed.
  3. Nov 19, 2019 at 4:59 PM
    Possible but not likely for all 4 TPMS to fail together. Colder temps can have some affect on tire pressures and has triggered the TPMS in my vehicles. Found the tire pressure a tad low and after adding some air to my specs the TPMS remained off all winter. Get a reliable tire pressure gauge and adjust to specs. If the TPMs were damaged by the tire shop it would have triggered the warning light right away. Also some TPM batteries may only last 5-10 years....but odds of all 4 failing is quite low.
  4. Nov 19, 2019 at 5:08 PM
    As @aggrex mentioned. Temp changes will effect tire pressure and could trigger TPMs. My bad for not mentioning as I've been f'ing with mine here on the east coast. One day it's 25 the next 55.
