Fluid film, amsoil metal protector or crc corrosion inhibitor on the frame and underacarriage?
Discussion in 'Wrangler JK (2007-2017)' started by windy ridge kennel, Apr 19, 2020.
  1. Apr 19, 2020 at 4:52 AM
    windy ridge kennel
    windy ridge kennel [OP] Member
    david
    2015 sahara
    has or does anyone use fluid film,crc amsoil rust inhibitor or similar product on the frame and undercarriage? if so likes dislikes.thanks
  2. Apr 21, 2020 at 6:21 PM
    I use Armorall to prevent mud from sticking to the frame & underside. Cheaper than the stuff you mentioned.
  3. Apr 21, 2020 at 7:55 PM
    Fluid film is a good rust preventative but it's messy to apply, likely to be unpleasant to work under the vehicle and expect dirt to cling to the surface.
