Front right axle 94 YJ
Discussion in 'General Jeep Discussion' started by Stonema, May 22, 2020.
  1. May 22, 2020 at 7:51 PM
    Stonema
    Stonema [OP] New Member
    Mark
    94 Jeep Wrangler YJ
    Lift/ 37.5 tired
    Can you get and put a single solid axle in this Jeep that has no locking hubs? or do you have to put locking hubs and new spindles on it? Goes in and out of 4 wheel and inner axial seems to float left and right. Is there a spacer in there between axial and differential?
  2. May 23, 2020 at 9:42 AM
    USMC Lifer
    USMC Lifer Member
    1995 YJ
    Pro Comp 3/5 in spring lift, new Novak AX15 5sp, SYE from Adams, All new brakes from Power Stop, All new front end parts ie. ball joint tie rode ends
    I have a 95 YJ. I replaced the two piece front passenger side axle with a one piece and got rid of the vacuum disconnect altogether. Several of the after market houses offer a kit.
    aggrex and Bob like this.
