Fuel injector connector
Discussion in 'Wrangler YJ (1986-1995)' started by Jeepjoc, Apr 5, 2018.
  1. Apr 5, 2018 at 5:21 PM
    Jeepjoc
    Jeepjoc [OP] Well-Known Member
    Dennis
    Albertville, AL
    1995 YJ Wrangler Rio Grande
    I"ve had a persistent fault code 27 problem and thought I had it solved several times but it seems to keep coming back. Well, today I think I isolated it to a bad connection between the injector and it's connector. Seems that if I jiggle the connector with the engine running I get a rough running and code 27. The connector is loose. Is there a way to tighten the connector with out having to replace the sub harness or the connector itself?
    Cheers - Jeepjoc
  2. Apr 5, 2018 at 7:20 PM
    2oldjeeps
    2oldjeeps Well-Known Member
    98 and 2000 xj's 99wj
    you can splice in a new conn. cut and solder
    aggrex and Bob like this.
  3. Apr 6, 2018 at 5:48 AM
    Jeepjoc
    Dennis
    Albertville, AL
    Anyone know where to get just the connector with a pig tail???
  4. Apr 6, 2018 at 6:28 AM
  5. Apr 6, 2018 at 7:14 AM
    I had a rat chew through one of my injector wiring, I pulled one from my 97 and soldered it in. Good as new.
    I do prefer the ones from my 97 though as they have a tab on each side to push and release rather than having to pull a clip and pry them off as I had to do with my 93. I will likely swap them all over eventually but was just trying to make sure the engine transplant (from the 97) worked.
    A pull a part type junk yard would be another good source, look for an XJ Cherokee up until about 98 or 99 I believe.
    No more expensive than the aftermarket part is though you might as well go with a new one.
  6. Apr 6, 2018 at 8:02 AM
    After a near fire with a headlight connection I have started using Dielectric grease everytime a disconnect and reconnect an electric connection.
