Gas Leak Issue
Discussion in 'Performance & Tuning' started by Bushwacker, Dec 1, 2020.
  1. Dec 1, 2020 at 11:26 AM
    Bushwacker
    Bushwacker [OP] New Member
    1983 Jeep CJ7
    Really None
    if you have a carb that idles good and runs good, recently rebuilt, and after you run the Jeep for awhile and shut it off, gas seeps out at the base of the carburetor, brand new gasket was put on after the carb rebuild. any thoughts
  2. Dec 1, 2020 at 6:00 PM
    Been years since I last worked on a carburetor. Seems like the carb rebuild was incomplete or maladjusted. Keep a fire extinguisher handy in case of a gas fire as I’ve lost a vehicle during a test run after installing a new carb and manifold upgrade.
    LYFZGOOD likes this.
  3. Dec 2, 2020 at 8:33 AM
    Bushwacker
    1983 Jeep CJ7
    Really None
    thanks for the advice :)
  4. Dec 13, 2020 at 5:14 PM
    Justanotherjeeper
    2011 Red Wrangler 2 door
    paid cash for it.
    Probably the float isn’t set up right, and doesn’t shut off the gas flow correctly once the engine is shut off. Just a guess.
