Heater not working
Discussion in 'Wrangler YJ (1986-1995)' started by Jeepguy2468, Oct 12, 2024.
  1. Oct 12, 2024 at 6:06 PM
    Jeepguy2468
    Jeepguy2468 [OP] New Member
    So I lost my heater and after finally getting the right motor and resistor I reinstalled everything just to find out that it still doesn’t work.
    Is there a relay or a fuse that I’m missing here..
    Frustrating
  2. Oct 13, 2024 at 12:28 PM
    is the heater motor not working or you don’t feel any heat inside the Jeep?
  3. Oct 13, 2024 at 12:59 PM
    Jeepguy2468
    It’s not working. That’s why I was wondering about a fuse or relay, I can hard wire it to a toggle I have but I need an inline fuse but I’d rather not make it janky
  4. Oct 13, 2024 at 2:21 PM
    Right I understand I thought maybe the motor was working, but you cannot feel the heat and one of the doors on the ductwork was not opening. I had that problem and it was a vacuum line
  5. Oct 12, 2025 at 4:59 AM
    Jloshotz
    Jloshotz New Member
    1994 Jeep YJ
    There is a little white vacuum switch on the heater control with three vac ports and maybe a micro switch on the heater control as well IIRC that energizes the fan i believe. Have you tsken a look there? Just a thought ✌
