Hellllppppp Doors won't come off
Discussion in 'General Jeep Discussion' started by JeepwranglerX, Aug 18, 2017.
  1. Aug 18, 2017 at 6:31 AM
    JeepwranglerX
    JeepwranglerX [OP] New Member
    I have a 2 door Jeep Wrangler x 2007 and the doors won't budge I thought that I had bolts on the top parts but when I tried using a socket wrench they wouldn't come out. Any ideas?
  2. Aug 18, 2017 at 6:42 AM
    JeepwranglerX
    IMG_1268.jpg IMG_1285.jpg This is what they look like
  3. Aug 18, 2017 at 6:49 AM
    As long as you took the nuts off keep working at it, it's always tight the first time.
  4. Aug 18, 2017 at 6:57 AM
    JeepwranglerX
    It didn't come with any bolts on the door I think they are nuts but I can't get the ratchet to grip on to what I think are nuts.
  5. Aug 18, 2017 at 7:07 AM
    There are t50 torq nuts that appear to have already be removed. You might try spraying some penetrating oil up in there, looks pretty gunked up.
    Here's what the kind pin looks like.
    OFFGRID, aggrex and chris4x4 like this.
  6. Aug 18, 2017 at 7:24 AM
    Welcome aboard!
  7. Aug 18, 2017 at 11:24 AM
    Billy1234
    Billy1234 Well-Known Member
    William
    1997 XJ 2 door
    None yet
    I have this same issue i think its just cause its a few years old idk what it is i think yhey sell a kit for it
  8. Aug 18, 2017 at 2:05 PM
    JeepwranglerX
    Thank you this has helped out alot
  9. Aug 18, 2017 at 3:25 PM
    Welcome! The pics show significant corrosion which will require some heavy use of rust penetrant to dissolve the corrosion. You may have to resort to a block of wood propped up by a floor jack as you swing the door slowly to work the door upwards. This is a proven method but you must avoid the loose off-balance door dance where it lifts off abruptly as you try to avoid dropping it or ramming it into the jeep. Once the door(s) are successfully removed the cleanup begins. Sand off the corrosion, discard the rusty metal liners and look at getting some Delrin liners so this won't happen again.
  10. Aug 18, 2017 at 7:26 PM
    Oh frickin no. Another member that likes to take Cockeyed pics. See why I have dain bramage. The constant headaches. Lol.
    Welcome to the forum jeepwranglerx. Apparently you went to the school of photography by aggrex. o_O. It's all good. What's another headache. Lollll.
    As far as the issue with your doors. You got some very good advice from some questionable members. :notsure:. But they do know their shit. Take their advice. And you'll be running naked in no time. :jellydance:
