Horn, airbag warning
Discussion in 'Wrangler TJ (1996-2006)' started by Jimjay 1053, Jun 6, 2019.
  1. Jun 6, 2019 at 7:54 AM
    Jimjay 1053
    Jimjay 1053 [OP] New Member
    James
    2000 jeep cherokee sport
    None
    Hi All,
    I recently erased trouble code to reset Check engine lite.
    Now the airbag warning is on all the time, (started to come on intermittently after reset.)
    Is there a loose wire or connection hiding in plain sight?
    I did remove the dash to replace heater core about a year ago.
  2. Jun 6, 2019 at 9:36 AM
    Always be careful with airbag (SRS) systems.
    Does your horn and cruise control work?
    FYI- clockspring is first thought with SRS light - codes will tell.
    What codes did you erase?
  3. Jun 6, 2019 at 10:25 AM
    Jimjay 1053
    James
    None
  4. Jun 6, 2019 at 10:27 AM
    Jimjay 1053
    James
    None
    Erased check engine light.
    I will check cruise.
