How do I disable Security on 1995 G.C. V8
Discussion in 'Cherokee' started by DGK, Aug 19, 2016.
  1. Aug 19, 2016 at 11:25 AM
    DGK
    DGK [OP] Member
    1995 Grand Cherokee Orvis
    I imagine there's a fuse or relay somewhere (??).
  2. Aug 19, 2016 at 12:21 PM
    You need to ground the purple & yellow striped wire that's in the driver kick area. That'll disable the security system.
  3. Jan 31, 2020 at 5:31 PM
    cpttuna
    cpttuna Well-Known Member
    earl
    XJ-98-00-01-and 01
    ss exhaust-viper coil
    I have a 94 GC. I looked at several threads. I had to remove the security relay to the left of the glove box to fix mine. None of the other ideas advanced worked for me.
  4. Mar 30, 2020 at 7:24 PM
    cpttuna
    earl
    XJ-98-00-01-and 01
    If its like my 94, the is a relay the the left of the glove box. I removed that and it solved my problem which was I could not start my GC and keep it running . Try using google. there are also several u tubes on the subject
