How to test AC compressor?
Discussion in 'Wrangler TJ (1996-2006)' started by Adam39601, Apr 30, 2019.
  1. Apr 30, 2019 at 7:33 PM
    Adam39601
    Adam
    2001 jeep wrangler sport
    How do you check to see if ac compressor works? it is not cooling and I know it has freon
  2. Apr 30, 2019 at 7:35 PM
    Ive always used gauges.
    TJ_abuser, aggrex and JKBob 25 like this.
  3. Apr 30, 2019 at 8:52 PM
    You can watch the clutch engage and disengage have some flip a/c on while you watch the compressor if it don't engage the system most like has a pressure switch on the accumulator it maybe low on freon
  4. Apr 30, 2019 at 8:53 PM
    If the clutch is engaging and it's still not cooling then issue is going to be more serious oh and welcome from Texas
  5. Apr 30, 2019 at 9:08 PM
    @Adam39601 is there any screeching noise from the compressor when the a/c is turned on or just the normal click when a/c turned on? @TJ_abuser are these possible signs of low freon or a bad clutch or bad compressor?
  6. May 1, 2019 at 4:53 AM
    There is aggrex but without gages.... You can ohm out the clutch coil .
    aggrex[QUOTED] likes this.
  7. May 1, 2019 at 5:57 AM
    lets start with you do not have any freon, WHAT !! system does not use freon*.
    If you have trouble deciding if AC clutch is operating I suggest you seek a professional to assist.
    Are there ANY codes? Some issues/codes and the PCM will restrict AC on.
    The key to AC work is GAUGES both high and low readings.
    Can you check - fuse box fuse #11 and PDC fuse # 21
    * R134a 'suva' or just say refrigerant.
