HVAC issue
Discussion in 'Grand Cherokee' started by ponty56, Jul 31, 2020.
  1. Jul 31, 2020 at 5:32 AM
    ponty56
    ponty56 [OP] New Member
    Jake
    1999 Jeep Grand Cherokee, 2005 Jeep Grand Cherokee
    Ok, i got one for the HVAC gurus. 1999 4.0 single zone climate control.
    Long story short i needed to replace a radiator and ended up replacing a bunch of stuff because I was already in there.
    So i vacuumed the system down to 25 inches, let set for 45 min and it held. Vacuumed down again for an hour, because the system was open to atmosphere for a while. Charged on the low side with the specified 24 oz.
    Here is my issue. During the time that I was charging the system I had it on vent and the ac button pushed bada bing bobs your uncle worked like a charm cold as ice. Take the jeep for a test drive to see if there are any coolant or transmission fluid leaks and on my way home ac stops.
    Now it works on defrost ice cold. But the second I switch to a different zone it shuts of the led ac switch and the cluch shuts off.
    Now before you say blend door I have perfect air movement in all other zones heat or ac. But it just flat out shuts the compressor clutch off.
    I know these pressures arnt perfect for 86° but just for reference and like I said ice cold.
