I messed up
Discussion in 'General Jeep Discussion' started by Danno1956, Apr 17, 2025.
  1. Apr 17, 2025 at 12:39 PM
    Danno1956
    Danno1956 [OP] New Member
    99 yj 2.5 5sp
    I have an 89 yj 2.5l 5sp. I was wiring up a light bar and I screwed up and put power to the ground. It melted wires behind the dash. The most affected wire was the ground to the wiper motor. I have replaced/repaired all that I could see, now I have crank but no start. Fuses appear to be fine. Any suggestions for a direction. TIA
  2. Apr 18, 2025 at 6:52 AM
    MTgeezer
    MTgeezer Well-Known Member
    John
    55 CJ 3B
    You may have taken out the engine control unit with that exercise.
  3. Apr 18, 2025 at 1:15 PM
    Barring more serious damage, I'd start testing each fuse in the box(s). Getting good crank is decent sign but getting her to run and stay running is key so fingers crossed against an ECU issue.
    LYFZGOOD likes this.
