Inch of play before wheels start turning
Discussion in 'Cherokee' started by Billy1234, May 20, 2019.
  1. May 20, 2019 at 3:05 PM
    Billy1234
    William
    1997 XJ 2 door
    None yet
    So my 1997 XJ has about a inch of play before it starts to actually turn the wheels. Any idea what that could be? Everything is stock.
  2. May 20, 2019 at 3:45 PM
    I would start with bushings, and make sure everything is tight.
    JKBob 25 and Billy1234[OP] like this.
  3. May 20, 2019 at 4:05 PM
    Billy1234
    William
    1997 XJ 2 door
    None yet
    Thanks @chris4x4
    chris4x4[QUOTED] likes this.
  4. May 20, 2019 at 4:23 PM
    I think there is a jam nut and bolt on top of the of the steering box that will force the pinion further down into the ring gear bit if this needs to be done it's a sign the gears are well worn and prob better to replace steering box they are not that expensive.
  5. May 20, 2019 at 8:21 PM
    Had same issue with my 2000 XJ. Tried a streering box brace and replaced bushings with polyurethane. Cleared most of the play up. Just figured at that point....it was an XJ characteristic. But an inch is quite a bit of play..
    So you find a fix dude??
    Billy1234[OP] likes this.
  6. May 21, 2019 at 7:33 AM
    Billy1234
    William
    1997 XJ 2 door
    None yet
    I'm ganna go threw it today after I get out of work if it's nice out will post up what I find out
  7. May 22, 2019 at 2:46 AM
    Billy1234
    William
    1997 XJ 2 door
    None yet
    So @TJ_abuser was right on the money I tighted the nut and bolt on top of the steering box still had a ton of play so went threw bushings that dont look to bad but I need a new steering box. Oh well not to bad
    chris4x4 and JKBob 25[QUOTED] like this.
  8. May 23, 2019 at 3:08 PM
    Billy1234
    William
    1997 XJ 2 door
    None yet
    Need advice on spacers that are sorta cheap but good my rear tires are rubbing on the side walls on the inside got about a 1/16th took off
  9. May 23, 2019 at 3:31 PM
    Running SpiderTrax spacers on my JK. Stick with quality brand, hub-centric and installed/maintain correctly.
  10. May 23, 2019 at 6:24 PM
    I'm running Rugged Ridge 1 1/2 spacers. No issues. I also check them every tire rotation. AND, as @aggrex makes us aware of. Don't forget to remove the retaining clips on the lug studs.
  11. May 23, 2019 at 6:57 PM
    Do you have a 2 inch lift? If so you can fix that with a adjustable rear track bar also is it only the drivers side rubbing or both? Mine was only on the drivers till I put on adjustable track bar . Smells nasty too as it's rubbing off slowly.
  12. May 23, 2019 at 6:59 PM
    I went with offset wheels cuz I'm way old school and do not believe in spacers.
  13. May 24, 2019 at 7:58 AM
    Billy1234
    William
    1997 XJ 2 door
    None yet
    I would so rather do new wheels then spacers but I dont have the money for wheels right now just spacers so I gotta go with that sadly but I wont been wheeling it anytime soon so I should be ok
    TJ_abuser[QUOTED] and JKBob 25 like this.
  14. May 24, 2019 at 10:15 AM
    Whether wheeling, yahooing or daily driven quality wheel spacers proper installation > thread locker > torqued can be a viable alternative to new wheels. IMO the thin cheaper pot metal lug centric wheel spacer designs probably gave wheel spacers a bad reputation. The 1.5" SpiderTrax wheel spacers are machined billet aluminum with pressed in studs. Don't use the thin pot metal washer type spacer or adapters.
    TJ_abuser, JKBob 25 and Billy1234[OP] like this.
  15. May 24, 2019 at 11:00 AM
    Billy1234
    William
    1997 XJ 2 door
    None yet
  16. May 24, 2019 at 11:56 AM
    Billy1234
    William
    1997 XJ 2 door
    None yet
    I should prolly make a thread for this but whatever I'll keep it going here. So would the rugged ridge fit my xj I only see fitments for wranglers I know I got the same bolt patter just wanna know if I'm right with them fitting my xj
  17. May 24, 2019 at 7:25 PM
  18. May 24, 2019 at 8:01 PM
    TJ Wrangler had 5x4.5 bolt pattern.
    I too would rather have offset wheels but it wasn't in the budget so I am currently running these and haven't had an issue.
    RockTrix for Precision European - 2pc 1.25" Thick Hubcentric 5x4.5 Wheel Spacers (71.5mm bore, 1/2" studs) for Jeep Cherokee XJ Grand Cherokee ZJ Wrangler YJ TJ Liberty KJ KK Comanche (32mm 5x114.3) https://www.amazon.com/dp/B01KPIUC7C/ref=cm_sw_r_cp_apa_i_79k6CbRYSMS53
  19. May 24, 2019 at 11:18 PM
  20. May 24, 2019 at 11:19 PM
    And I have 5 factory aluminums for sale my originals
