Interchangeable transmissions?
Discussion in 'Wrangler YJ (1986-1995)' started by CLINTOK420, May 19, 2020.
  1. May 19, 2020 at 8:04 AM
    CLINTOK420
    CLINTOK420 [OP] New Member
    95 jeep wrangler yj
    So I have a 95 jeep wrangler 4.0 with an automatic transmission. The trans slips in 1 and second gear. My question is can I use a transmission from another jeep model like a cherokee. Its hard to find used parts and I know new is best but I'm just starting out.
  2. May 19, 2020 at 10:24 AM
    Welcome @CLINTOK420 ...I'm no trans swap guru but present your issue to Novak conversions as they should be able to tell you what fits or not. Always good to be saving the "squares". Post a pic or 2
    https://www.novak-adapt.com/
    CLINTOK420[OP] likes this.
  3. May 19, 2020 at 11:05 AM
    SrdjanDV
    SrdjanDV Active Member
    Srdjan
