Is the same set of Bilstein 5100s compatible with different vehicles?
Discussion in 'Suspension' started by jshaw2013, Feb 14, 2021.
  1. Feb 14, 2021 at 9:08 AM
    jshaw2013
    jshaw2013 [OP] New Member
    Jay
    2016 Jeep Grand Cherokee 4x4 limited.
    Hey everyone. My brother has some bilstein 5100 shocks he took off his 4 runner 2016 (he had then put on)
    May be ignorant question but are these universal? Hence, will they fit a 2016 Grand Cherokee Limited 4x4? Or do they make specific vehicle types for bilstein 5100s?
    thanks!
  2. Feb 14, 2021 at 9:29 PM
    @jshaw2013 . Not necessary. They do make them for specific lift heights That being said. As long as your mounting points are the same. Ex. 2 bolt, pins, or studs. Or whatever 4 Runner mounting points are. It's a Jeep forum. If your running a stock suspension and stock shocks. You can use them. As long as they are at a stock length. With no lift. And mounting points match up. You can use them.
    Hope this helps.
    Justanotherjeeper and aggrex like this.
