it sound like a miss
Discussion in 'Other Jeep Vehicles' started by jkann1, Jul 20, 2017.
  1. Jul 20, 2017 at 8:15 AM
    jkann1
    jkann1 [OP] New Member
    Commander
    Hi all, New guy here I have a Jeep Commander it runs great but it has a miss I thing ...you hit the gas and it take off but it has a jerking or like a miss fire has I accelerate .. its a 5.7 Hemi in it.I told the wife I will check the plug wires etc and fix it... I took the motor cover off wow wheres the spark plugs I'm lost does any body have any ideas...Thanks for your time
  2. Jul 20, 2017 at 8:51 AM
    teamdirtbash
    teamdirtbash Member
    Dirtbashjku
    2014 Wrangler 4 door
    Stinger , smitty built winch , cold air , 93 tune , 30 inch Cooper tires stock height . Will update when I do more
    My idea is to buy "anti jerk" product I purchased one for my 5.2 ZJ who has this same problem . Lucas makes great products but I'm sure u can find some thick additive that's cheaper meant to fix "transmission jerk" I hope this helped but again I'm just going off of what I read.
  3. Jul 20, 2017 at 9:45 AM
    Welcome to the site!
  4. Jul 21, 2017 at 6:40 AM
    SmittyJeeper
    06 wrangler 4.0 6speed
    The 5.7 hemi engine has 16 spark plugs and they are under the coils. This engine is a coil on top of the spark plus design in other words. ONLY! Use OEM copper plugs with this engine. If you change them yourself or go to a shop OEM copper plugs should be the only plug installed or the engine will have problems. Remember it 2 plugs per cylinder and they are good for about 30k per set. This is a temperamental engine. Always check for codes a common problem with these is the oil pressure sensor, believe it or not it will cause the same problem or even a no start as it shares a power with the CKP sensor.
  5. Jul 21, 2017 at 7:19 PM
    Not very familiar with hemi's. Thanks Smitty Jeeper. You learned me some thing. :).
    Curious what the issue is. Keep us posted jkann1.
    Welcome to the site.
