Jeep Liberty help...please!
Discussion in 'Liberty' started by jeepmom, Nov 1, 2016.
  1. Nov 1, 2016 at 6:14 PM
    jeepmom
    jeepmom [OP] New Member
    2004 limted jeep libert
    I'm in need of tips or ideas of other things for my mechanic and the dealer to look for on my sons 2004, 3.7 limited jeep liberty. I apologize in advance, as there is no short version to what happened! I'll start with what happened after it went all levels of crazy and what was found.
    After replacing the BCM, fuse box and ignition switch our blue bomber still tried to short out the diagnostic scanner. It was towed to a dealer and almost blew their scanner and they went thru the wiring by hand. What they found was the wiring harness that runs along the drivers side in the headliner, had had a mouse in it, who had loads of fun chewing on the wiring and left it an exposed, melted wiring mess. We have replaced the BCM, fuse box, ignition switch, speed sensors, rear differential sensor
    and said wiring harness. We now have a jeep with the below not working...which it all was prior to breaking down. We have tried to clear the codes from the check engine light and as soon as it's turned off, it immediately comes back on...
    No speedometer
    No odometer
    No sunroof
    No rear wiper working
    No rear lift window working
    No working key fobs(batteries have been replaced)
    No working console above rear view mirror
  2. Nov 1, 2016 at 6:59 PM
    Welcome! Wow! That's quite the list. Hopefully someone might have something for you to try.
    jeepmom[OP] likes this.
  3. Nov 1, 2016 at 7:08 PM
    jeepmom
    Thanks! It is quite the list and thank goodness for comprehensive insurance! My IT working brain keeps saying somethings not reading the BCM completely or something missed when it was programmed! It's sad, because it has minimal rust being in NNY and only has 74,908 miles on it! Needless to say I will never feel sorry for a mouse our cat catches. They are no longer cute after this damage.
  4. Nov 1, 2016 at 7:38 PM
    C2T
    C2T Well-Known Member
    Richard
    Helena, Montana
    Jeep
    Well, I guess I would start by re-checking the fuses if you have not. What you describe should have blown a bunch of them. Next, I would be making sure the individual items are not blown/damaged by the shorting that occurred. Like making sure the rear windshield wiper or the one windows motor is still good (for example). I would just be trying to narrow some things down.
    Sounds like a tough nut to crack...good luck with it.
  5. Nov 1, 2016 at 7:48 PM
    jeepmom
    It has become a pain to crack! We no sooner get one thing fixed and running, we find something else...ugh! The dealer called it a gem and well my regular mechanic has a few choice words for it...haha. They both said they were surprised it didn't catch on fire. After seeing the harness with charred wires and an 8" section of it so melted it's rock hard, electrical tape melted into the padding.
  6. Nov 2, 2016 at 9:43 AM
    Sounds like a big mess. I do believe that you can reset the computer by disconnecting the battery for 72hrs. I believe this will also reset your check engine light. Then do what Richard said. Test each individual component. Not sure about the new jeeps, but the old jeeps electrical components can fry with power surges which sure sounds like what happened. Anything that has a switch going to it i.e. window, wiper, etc you'll want to make sure the switch is good. Good luck.
    C2T and Bob like this.
