Jeep Liberty radio loses memory when ignition is turned off
Discussion in 'Liberty' started by red1, Apr 20, 2017.
  1. Apr 20, 2017 at 6:05 AM
    red1
    red1 [OP] New Member
    red
    1992 black jeep wrangler
    2012 Jeep Liberty radio loses preset stations and time when ignition is turned off.
  2. Apr 20, 2017 at 8:46 AM
    Is it an aftermarket radio?
  3. Apr 20, 2017 at 3:32 PM
    Whenever I disconnect the battery from a vehicle during service I can expect the loss of stations and/or clock. On some systems the stations or clock is restored if power is returned shortly. Is your station or clock memory lost over night or instantly? Radio may be defective or the radio could be wired up wrong since some accessories work without the key (constant) and others require the key (switched).
    OFFGRID likes this.
  4. Apr 20, 2017 at 8:34 PM
    Yep. That's what I was getting at.
