Jeep won't start and check engine light now on
Discussion in 'Wrangler YJ (1986-1995)' started by Jeepjoc, Sep 25, 2017.
  1. Sep 25, 2017 at 8:55 PM
    Jeepjoc
    Jeepjoc [OP] Well-Known Member
    Dennis
    Albertville, AL
    1995 YJ Wrangler Rio Grande
    Today I took my jeep to the gas station to fill it up. After filling it up I jumped in and turned the key and got nothing. My wife was with me and I had her behind the wheel and pushed her to get it started. Drove home and the jeep ran beautifully except the "Check Engine" light did come on. Parked in the drive way and decided to try again, nothing. Anybody got any ideas about where to start looking. My thoughts at this point is ignition.
    Cheers - Jeepjoc
  2. Sep 26, 2017 at 6:55 AM
    Starter Relay, Starter, ignition, weak battery. Check the easy stuff first. See if you can jump it. Check battery cables for good solid connection.
  3. Sep 26, 2017 at 8:24 AM
    Since the engine light appeared I would try to get the code to help with the diagnosis of the underlying proble in addition to what OffGrid offered as steps.
  4. Sep 26, 2017 at 6:53 PM
    Agreed. I'm sure you know, your in good hands. I may not be able to help....But I'm sure other members might be able to.
    Subbed to see the outcome. Good luck Jeepjoc.
  5. Sep 27, 2017 at 2:03 PM
    dballhead
    dballhead New Member
    97wrangler
    None yet
    Before you go all crazy jump start the jeep while it is running remove one side off the battery terminal if jeep cuts off your alternator is bad if it stay running replace terminal then do other tests ,good luck!!
  6. Oct 5, 2017 at 1:58 PM
    Jeepjoc
    Dennis
    Albertville, AL
    Update. After doing all the checks that I could think of, it turned out to be a bad battery. Checked the battery date and it was a little over six year old battery, so I guess it didn't owe me anything.
    Cheers & Beers - Jeepjoc
  7. Oct 5, 2017 at 2:02 PM
    Thanks for the update. The lowly but highly valuable battery lasted 6 years and decided to fail before the winter season.
  8. Oct 5, 2017 at 2:47 PM
    Jeepjoc
    Dennis
    Albertville, AL
    Yep, Now gotta start thinkin' about puttin' all the side curtains back on!!!
  9. Oct 5, 2017 at 4:16 PM
    Offroad798
    Offroad798 Well-Known Member
    Florida
    2015 Rubicon
    Hey just seen your post. Just throwing my two cents out again. We are talking basics here. Barring accidents, water damage, wrecks and human error etc. The CEL light usually turns on when it detects a sensor that goes out of tolerance that directly affects emissions. They will call the sensors around your engine and exhaust. If the voltage to the computer drops too low you will have all kind of weird things happen. Voltage goes to high you can fry the computer hence trickle charge. Since the electrical system is not part of emissions it will not call out the starter, alt DIS, etc. This comes down to the tech using meters and a scanner to help T-shoot a problem. Careful on pulling battery cables of while vehicle is running, work great on older vesicles ( non computer vehicles). Ever had the problem while driving everything works good. Then stopped at a red light the car ran really bad and died. Well the alt is running the car while driving and at idle the battery handles this job. They do compliment each other. Same reason why you idle up when winching. Just keeping it simple here. Did you ever find out what the code was? Glad you got it fixed.
  10. Oct 5, 2017 at 6:04 PM
    Cool you found the issue. Thanks for the update. I could bust your balls on it. But I'll leave ya alone this time. Lollll. :cheers:
