JK 2013-up firewall/wires
Discussion in 'Electrical' started by jeepavalanche, Oct 31, 2019.
  1. Oct 31, 2019 at 11:30 AM
    jeepavalanche
    Just curious if anyone knows where to go through the firewall so I can run some power cords to my battery for cb radio and amp.
  2. Oct 31, 2019 at 11:54 AM
    Passenger side, pop the end of the dash off.
    There will be a small hole that has spray foam in it.
    Use a length of wire (like a hanger) and poke through it and it will come out just inside the front fender within easy reach of the batter.
    I have a picture but it will be a bit before I can post it.
  3. Oct 31, 2019 at 1:13 PM
  4. Oct 31, 2019 at 7:45 PM
    @jeepavalanche ....there is a similar foam filled hole on the driver-side that can be used for other future upgrades.
  5. Nov 1, 2019 at 5:26 AM
    jeepavalanche
    Thank you. I need to get some 6 gauge power and ground wires through there for my linear and smaller power/ground for the citizens band radio. This is a great point of entry.
  6. Nov 5, 2019 at 5:26 AM
    jeepavalanche
    I tried that but it came on the outside of the firewall
  7. Nov 5, 2019 at 5:36 AM
    Those foam-filled holes are just one-type of pass-thru from interior to exterior. To cross over into the engine area just use some abrasion resistent wire covers. For AT models just below the MC is a grommet that can be used. Above the MC is another grommet wires can pass-thru although a bit trickier with bends.
    jeepavalanche[OP] likes this.
  8. Nov 5, 2019 at 5:37 AM
    It's still under the hood so it's protected and not seen. There is a wire loom right there to cleanly run the wires along to the battery.
  9. Nov 5, 2019 at 2:02 PM
    jeepavalanche
    Forgive my ignorance, what is MC?
  10. Nov 5, 2019 at 2:04 PM
    jeepavalanche
    True, it can be done that way. Thats what i did for the citizens band radio. The wires for the linear are going to be 6 gauge power and ground so i will have to go through firewall
  11. Nov 5, 2019 at 2:06 PM
    Sorry have to look the part at work lol. Master cylinder
  12. Nov 5, 2019 at 2:07 PM
    jeepavalanche
    Thanks, I will look at it.
