JKU Sport vs Rubicon electrical wiring
Discussion in 'Wrangler JK (2007-2017)' started by phonedrn8, Sep 28, 2017.
  1. Sep 28, 2017 at 6:58 PM
    phonedrn8
    phonedrn8 [OP] Member
    Jimmie
    no jeep yet looking into JT
    Are all jeeps built the same as in the wiring dept for both versions . Does the sport have wiring in place if you upgrade to e lockers or heated seats, buttons , something about a 110 inventor? If I get a sport and later upgrade to d44 lockers and other stuff
  2. Sep 28, 2017 at 7:30 PM
    12V accessories such as heated seats can be hooked up to switched or constant power. The Jeep parts dept should be able to determine whether different harnesses are used for your specific year/model.
  3. Sep 29, 2017 at 8:56 AM
    Things like the lockers, disconnect, and such, aren't wired up on the sports, or Sahara models.
    Bob, JKBob 25, aggrex and 1 other person like this.
  4. Sep 29, 2017 at 10:22 AM
    Installing OEM Rubi axles will require additional wiring harness if available. Otherwise wire them up yourself with available 12V switched power since you will need switches to turn them on anyway.
    Bob, JKBob 25 and chris4x4[QUOTED] like this.
  5. Apr 2, 2018 at 1:39 PM
    Billy1234
    Billy1234 Well-Known Member
    William
    1997 XJ 2 door
    None yet
    I’ve been looking in to finding a couple Rubi axles for me and my father in law he needs to re build his anyways and just wants to throw one of those on
  6. Apr 2, 2018 at 1:47 PM
    Upgraded front axle is on my distant wishlist too but sometimes the asking price is high and/or the Dana 44 has had a hard life making me consider searching the aftermarket. Advantages are new, geared the way you want, locked the way you want, bolt-on ability as if you can take it off you can install. Spending more you can upgrade axles shafts, knuckles, ball joints etc. Of course you may get lucky and find that unicorn Dana 44 in good condition from an owner moving up but then you have to match the gears to what you're running. JEEPS: just empty every pocket(s) :)
    JKBob 25 and Billy1234 like this.
  7. Apr 2, 2018 at 2:18 PM
    Blue Baby Sound
    Jeff
    Build threads in sig
    There are two different wiring harness used for the sport, one them them is also used for the Rubicon. If you have power locks, windows etc then you have the same one.
    BUT
    That doesn't mean you can do what you're asking. Your best bet is to install a separate device to control the electrical additions you make. I have one of these sitting in a box to add to ours to control the lockers, heated seats and other things. I have no experience to offer but it's a nicely built piece and I have high hopes for it :)
    https://www.amazon.com/Apollointech...8&qid=1522703871&sr=8-1&keywords=apollointech
  8. Apr 2, 2018 at 2:19 PM
    Blue Baby Sound
    Jeff
    oops, sorry, just saw I was responding to a 6 month old thread......
  9. Apr 2, 2018 at 2:19 PM
    Billy1234
    William
    1997 XJ 2 door
    None yet
    I did the same lol
  10. Apr 2, 2018 at 2:24 PM
    Old or not, it's good to get fresh input! :bikewheelie2:
  11. Apr 2, 2018 at 2:24 PM
    Billy1234
    William
    1997 XJ 2 door
    None yet
    Exactly!
  12. Apr 2, 2018 at 7:06 PM
    So....awesome input guys. Grabbed my attention.
  13. May 24, 2018 at 5:30 PM
    Automan21
    Automan21 Well-Known Member
    That light switch pod looks pretty damn nice. I might just order one.
