Largest tire for a JK with a 2.5" lift?
Discussion in 'Wrangler JK (2007-2017)' started by RWB333, Aug 25, 2017.
  1. Aug 25, 2017 at 11:23 AM
    RWB333
    RWB333 [OP] New Member
    2017 JK
    What's the largest size tire you can fit with a 2½" lift? I've got 35's right now but I'm wondering if I can get 37's on my JK. Anyone know?
  2. Aug 25, 2017 at 12:07 PM
    Welcome! Flat fenders will go a long way to make it all fit for the street.
    JKBob 25 and Rc Jeep like this.
  3. Aug 25, 2017 at 12:09 PM
    Welcome aboard!
  4. Aug 25, 2017 at 1:47 PM
    RWB333
    2017 JK
    Awesome! That's an easy mod
  5. Aug 25, 2017 at 1:48 PM
    RWB333
    2017 JK
    Thanks guys!
  6. Aug 25, 2017 at 6:35 PM
    Welcome to the boards RWB333.
    Isn't it funny how guys always want our stuff bigger. (Leave it alone JMM). When I bought my JK, I told myself I was only going to install a 2 inch lift with 33s. Which I did. Less than a year. I want 35s and jump up to a 3 1/2 inch lift. Jeepers are always looking to upgrade.
  7. Aug 25, 2017 at 9:39 PM
    If you take your fender flares off you can run 37s. To be legal you will need to get aftermarket flat or tube fender flares.
    Here is my friends Jeep 40s with 2.5in lift. This takes a little more work, but he can run any trail you put him on.
    RWB333[OP] and JKBob 25 like this.
  8. Aug 26, 2017 at 6:38 AM
    Rc Jeep
    Rc Jeep Well-Known Member
    Ryan
    '16 Rubicon
    those look like MCE fender flares. The most expensive plastic in all the land!
