Largest tire on stock 2016 Wrangler?
Discussion in 'Wrangler JK (2007-2017)' started by Dolphin1962, Dec 2, 2019.
  1. Dec 2, 2019 at 4:24 AM
    Dolphin1962
    Dolphin1962 [OP] New Member
    Russ
    Jeep Wrangler Sport 2016
    None
    What is the biggest tire I can put on a stock 2016 jeep wrangler sport
  2. Dec 2, 2019 at 10:11 AM
    Welcome to the site! Generally, with stock height, you can install a 285/70/17 tire (assuming you have the factory 17" wheels). You might need a set of wheel spacers installed if you have rubbing at full turn.
    aggrex and Bob like this.
  3. Dec 11, 2019 at 2:48 AM
    Hammer12b
    Hammer12b Member
    Hickory, NC
    2018 JKU Willy’s, 17 Willy’s JK and a 00 TJ Sport
    2 inch lift
    You might want to consider the gear ratio also. The bigger the tire, the more power you loose if it’s geared 3:21.
