Loose Front End, Need Suggestions
Discussion in 'Cherokee' started by skinny1371, Sep 5, 2022.
  1. Sep 5, 2022 at 3:53 PM
    skinny1371
    skinny1371 [OP] New Member
    1999 Cherokee XJ
    Anyone that can help me, I sure would appreciate it. Have a 99 XJ that I’ve went through pretty much front to rear, but finally decided to tackle the front end bits I passed over the first time. I just replaced the axles, upper and lower ball joints, and the hub assemblies. There are all new brakes and calipers, lines, etc. everything but the knuckle itself is new. Drove it today and it’s absolutely a nightmare to keep in it’s own lane. Anything simple I’m overlooking? Any suggestions on where to start? I haven’t had it aligned yet, maybe that’ll help, but it doesn’t feel that bad out, it’s hunting something fierce.
    Thank you.
  2. Sep 5, 2022 at 6:51 PM
    Get a good shop for the alignment to rule out a variable and check for proper torque specs for the parts you have replaced and then some
    JKBob 25 and skinny1371[OP] like this.
  3. Sep 5, 2022 at 11:54 PM
    skinny1371
    1999 Cherokee XJ
    Thank you. I plan on getting the alignment done to see if that helps. I torqued everything to spec on install, but I’ll definitely check that again. This thing was so squirrelly it wasn’t even funny.
  4. Sep 7, 2022 at 12:13 PM
    MTgeezer
    MTgeezer Well-Known Member
    John
    55 CJ 3B
    My guess? Caster is way out of spec, assuming everything else is tight.
