Lost my cold air
Discussion in 'Cherokee' started by 2oldjeeps, Jun 28, 2017.
  1. Jun 28, 2017 at 9:38 PM
    2oldjeeps
    2oldjeeps [OP] Well-Known Member
    98 and 2000 xj's 99wj
    3 months ago on a warm day i tried my 2000 air cond. the comp short cycled. i added a little freon and it stayed on. added just a little more and buttoned up.
    it worked flawlessly , COLD, till 4 days ago.
    started up and felt/heard a faint vibration with air on, none with air off.
    it also dissappeared when i shifted into gear/loaded the engine.
    a day later the faint vib stayed in/out of gear, air still cold
    2 days ago the air was getting warmer, not as cold.
    i added a little freon, no help.
    today no cold at all, heard slight squeal. not sure if belt or compressor.
    compressor turns on/off with air /heat.
    air temp varies from hot to cool/ambient so blend door seems to be ok.
    good hot heat, no cold with comp running.
    any ideas?
  2. Jul 5, 2017 at 12:32 PM
    2oldjeeps
    cold again.new comp,dryer,orfice tube.lots of tedious work,about $400 in parts and tools.hope my workholds up!
    i dont like the gauges from harbor freight.
    finally charged it with a can and can guage till normal.
    tomorrow will tell!
  3. Jul 5, 2017 at 6:06 PM
    Hope your a/c problems have been solved as you replaced many of the possible culprits. Tough job to do during high temps and humidity levels. Did you identify any freon leaks?
  4. Jul 5, 2017 at 7:01 PM
    2oldjeeps
    no leaks,,,so far.will know tomorrow huh! nice tonite...
    im from kittanning!
  5. Jul 8, 2017 at 8:27 AM
    2oldjeeps
    aok,,,goes into 30's in recycle!!,,,38
